Offset and fitment
Old 01-08-2009, 05:09 AM
chiney_dolly's Avatar
Default Offset and fitment
hey guys.
i've seen some ppl run weird offsets, like +38 and so on in the rear
i found some decent wheels
just wanted to know what i would ahve to do to fit them
the front is 18x8 with a +40 offset
and the rears are 18x9.5 with a +40 offset
would i have to roll fenders and relocate the bumper tab and so on
what amount of rear camber would be good for this set up
thanks
Old 01-08-2009, 07:38 AM
rk604's Avatar
please read the sticky at the very top of the page on the forum....
it clearly states
"wheel fitment...."
Old 01-08-2009, 07:41 AM
ammm yes i have.... it give general fits.
i know this offset will need adjustment, i want to know what exactly id need to do... or if they will stick out by what amount.....
Old 01-08-2009, 08:31 AM
WashabiS2K's Avatar
your fronts should be fine with a little bit of camber. The rears will fit with a good amount of negative camber, rolled fenders, and relocated bumper tab. what size tires are you planning to run?
Old 01-08-2009, 09:40 AM
thank you VERY much wash
ammm not sure, was waitin on someone to reply as to how much modification i would need
what do you recommend?
was thinking 255/35 in the rear and 225/35 or 40 in the front
Old 01-08-2009, 09:52 AM
HUYS2200's Avatar
225/40 and 255/35
Old 01-08-2009, 10:06 AM
thanks much thats what i was more leaning to
another question,
been doing some readin and some other ppl where saying that 8inch wide rim wont fit with that offset?
like i said before i dont mind doing modifications to fit the wheels, jsut want to know what exactly i ahve to do
so just wanted to make sure, that with mods it will work
Old 01-08-2009, 12:04 PM
TrackStar's Avatar
You should be able to get that rim to fit up front. I have 8.5 +50 with a 225, but I recently raised my car to 2 finger gap between tire/fender. I bent the lining tabs by hand and I have zero rubbing issues. How low will you go?
Old 01-08-2009, 12:13 PM
ok niiice.
thanks
ammm well no specific hieght yet. i just want the car to be as low as
possible. its not going to ba a daily driver. so really as low as the rims can accomodate
what else did u have to do?
want to be a darlin and explain the process in detail, so i can know when im doing it myself hahaha
Old 01-08-2009, 12:32 PM
TrackStar's Avatar
Anything for you
Wheel/Tire:
Advan RS
17x8.5 +50 225/45/17
17x9 +29 255/40/17
Diameter will not make a difference- it's all about offset, width, and tire size.
For the front- really all I had to do was bend in the tabs that the fender lining clips go into. This is just done by hand. Keep in mind that I am running fairly stiff coilovers (Buddyclub racing Spec), which obviously makes the car less prone to compressing. As stated, I have about an inch of wheel gap as well right now. At the last alignment, I had my car set to stock front settings for camber.
For the rears, I have yet to install. I am waiting on my shop to have time to take me. I am adding an extension piece to the rear bumper to follow the ASM over fenders. I will have the inside of the wheel arch on the rear bumper trimmed, and the bumper bolt relocated to avoid rubbing. I am confident this set up will fit with moderate-stock amount of camber.
Quick Reply: Offset and fitment
