offset downfalls?
offset downfalls?
just picked up some blitz type 01 rims today. I'm running a...
17x7.5 51 front
17x9.0 45 rears
I bought these used so I couldn't be picky about the offsets. but I was wondering are there any downfalls with having a higher offset front than the rear?
17x7.5 51 front
17x9.0 45 rears
you can run a 245 but you have to run mad negative camber
you can run a 245 and roll your fender and run slight negative camber
you can run a 235 and and be on stock fender/stock alignment.
you can run a 225 up front, but run negative camber and not rub.
you can run a 215 up front and be perfect. No rubbing.
well hmm.. yeah.. ummm... according to the ..ummm wheel fitment guide that the smartest people in the um world put together that well.. says that these are .... not going to fit. ZOMG what are we going to do????
LOLLLLLLLLLLLLLLLLLLL
this fitment is about the sexiest wheel setup u could get the rears will actually fill the fenders rather than being sunk in 3" like stock.
dude, dont worry about what these guys say... u got the best of the best and the lower u go the better theyll fit.
