OEM lugs fits volks ce28n?
Old 08-01-2009 | 11:50 AM
calcal's Avatar
Default OEM lugs fits volks ce28n?
Does OEM lugs fit volks ce28n .. ?
Old 08-01-2009 | 12:37 PM
Jim@tirerack's Avatar
Former Sponsor
I would have to say no because we supply lugs with the wheels when we sell them. If they used the factory lugs we would not supply new ones. I have the lugs and centering rings available. If I can help let me know.
Old 08-01-2009 | 01:54 PM
calcal's Avatar
thanks jim,
only the rear needs the center ring is that right?
i bought it used, and it only have the rings for the rear ...
how much is a set of lugs ... preferably in blk color or red color
Old 08-01-2009 | 07:55 PM
Harpoon's Avatar
The whole "are the centering rings necessary" debate has been going on for years. If they are indeed "needed" they are needed for the fronts more than the rears. Science of Speed sells pink anodized rings that actually fit. I ordered multiple pairs of the plastic rings from Tirerack awhile ago and the fronts don't fit. The SOS ones are cheap enough and the anodized process helps to prevent them from getting rusted to the hubs.
And, yes - you do need to use aftermarket lug nuts. The oem ones will not work with these rims. At least not for long.
Old 08-01-2009 | 08:30 PM
GrandMasterKhan's Avatar
the oem lugs are acorn shaped and the volk lugs have a flat edge. if you use the wrong shape it will damage the wheel and eventually loosen.
Old 08-01-2009 | 10:29 PM
shotgunjimmy's Avatar
Old 08-01-2009 | 10:52 PM
AmazingGinsu's Avatar
FWIW
I ordered 2 sets of centering rings from Jim @ TireRack a couple of weeks ago for a friend and myself. RE30 and CE28N. They fit both the front and back wheels correctly. Jim was helpful and professional and they arrived quickly.
Also you do need after market lugs.
Old 08-02-2009 | 12:07 AM
GT_NFR's Avatar
Is there a link for these hub centric rings from SOS? Can't seem to find it.
Old 08-02-2009 | 06:43 AM
Harpoon's Avatar
They're listed under the NSX and not the S2000 for some reason.
http://www.scienceofspeed.com/products/ext...entering_rings/
unlewser
05-10-2011 06:40 PM
bradleybev
01-12-2009 12:36 PM
mkim12180
06-18-2007 07:19 PM
FMINUS
09-25-2006 09:39 PM
SerpentineGX
06-01-2006 06:54 PM
