O.Z. Ultraleggera/Eagle F1 GS-D3
Im looking for a little help....
Almost a year ago i bought a set of 18 inch OZ Ultraleggeras and ordered them with the Eagle F1 tires. The next day someone from tirerack called to point out a problem with my order. i was told the F1 tire would rub my OZ set up and suggested i go with the KDW-2 because the same size KDW would not rub. Its time for new rubber and i want to second guess Tirerack and reconsider a higher performance tire. My choice is still the Eagle F1 GS-D3. Does anyone know how bad it would rub or if it would realy rub at all? If it does rub could i get away with minor fender roll to fix it?
FYI: im running stock ride hight
Eagle F1 GS-D3
Front:
225/40ZR18 2
Rear:
245/35ZR18 2
KDW-2
Front: 225/40ZR18
Rear: 245/35ZR18
Wheel info
O.Z. Ultraleggera
Size Selected: 18x8 Front
Recommended Tire Size: 225/40-18
** Lightweight: 18.4 lbs. **
Size Selected: 18x9 Rear
Recommended Tire Size: 255/35-18
Wheel Offset: 55mm
** Lightweight: 19.6 lbs. **
Eagle F1 GS-D3
Front:
225/40ZR18 2
Rear:
245/35ZR18 2
KDW-2
Front: 225/40ZR18
Rear: 245/35ZR18
Wheel info
O.Z. Ultraleggera
Wheel Offset: 55mm
let me add one thing. the KDW-2 is an awesome tire and is a great value. everything is very good about the tire even the performance. i had not problem keeping up with people running a "better" tire on the dragon (please, no experience /driver skill comments). like anyone, im always looking for stronger, better, faster.
the recommended tire size is a 255.... would that be pushing it?
Wheel info
O.Z. Ultraleggera
Wheel Offset: 55mm
Wheel info
O.Z. Ultraleggera
Wheel Offset: 55mm
