NT03 metal valve stem install
I needed to know how to install the valve stems that come with the with my NT03'a. Im taking to my local shop for install but i wanted to make sure i knew how they went in case they did something dumb. I have the stem with the cap, rubber, nut, washer, rubber and bottom piece. What goes inside and what goes outside? Your input would be very appreciated.
This is the same as my advan valve stem.
The rim goes in between the two o rings. Use the last picture as the order. Makes a lot of sense there.
Hand tight with tools until the o ring looks like picture 2. I used deep socket instead of wrench. I think 10mm I forgot.
