nt03-m 17x9.5 fitment
hi, i have asm front fenders and rolled rear fenders.
Will i be able to fit nt03 rims in the size 17x9.5 with 38mm offset both front and rear?
Also what tire sizes will i be able to use?
Any help would be great!
they fit with flared front fenders! so they might work with ur fenders, the rears will fit easy, just depends what tire size u go with! common set up with that offset is 225/45 and 245/40
i saw people with 255 allready, so i am going 265 on my rear
but the weather in New york are still kinda cold now, so when the weather get's warm i will bring all the body kits and wheel to the body shop and fit it on...
i will post pictures on as soon as i did it...
255 x4 all around
1) Roll rear 1/4's, bumper tab relocated, cutting of the rear bumper, negative camber, bending of the metal pinch weld bracket thingy.
or step down a 245 x4. I will be a lot more safer, but the above info will give you make you rub free also, but its just more work involved.
