noob question about adjusting camber
Old 02-26-2007 | 11:35 AM
enigmadsm's Avatar
Default noob question about adjusting camber
Okay, this definetly applies to you crazy offset running people.
If you are running some pretty extreme offsets in the rear and are pretty low, how much negative camber are you running? What is a "safe" amount. I know it will affect handling, and cause more wear, but there is still a safe amount i would assume.
Also, here comes the noob part.................how do i adjust it? Do i have to take it to an alignment place and tell them what i want it set at?
Old 02-26-2007 | 11:57 AM
velocityracer's Avatar
very noob question......if you have to ask how to adjust it....dont try to do your own camber setup. Take it to a shop to do it. Dont know where you live but i've heard many good things about this guy who does aggresive camber set ups, forgot his name though. Anyone wanna let him know? his a guy in Cali
Old 02-26-2007 | 12:24 PM
rijowysock's Avatar
-2.5F -3.5R camber, i used to have -4 rear but toned it down because i was getting a lil understeer.
tire wear isnt an issue you get the same miles out of the tire if not more when u flip flop them @ about half tread. u can only flipflop directional tires.. ;-)
riley
Old 02-27-2007 | 08:14 AM
Jim@tirerack's Avatar
Former Sponsor
You will only be able to adjust the camber so far. At that point you will need a camber kit. Keep in mind the more negative camber you run the quicker the tires are going to wear on the inside shoulder.
theS2K
07-13-2015 12:05 AM
Sneeze2K
05-20-2013 02:30 PM
THE GEWYIST
04-04-2012 05:09 PM
slipper
08-25-2007 06:57 AM
kiltbunny
07-25-2006 06:19 PM
