The Noob needs help.
Old 04-06-2015, 08:50 PM
  #21
BloodMoonS2k's Avatar
I actually changed out the wheel hub and bearings and put extended wheel studs, sorry I should of mentioned it earlier. The only reason why I want the Seibon fenders, is because the air ducts would really compliment the look I'm trying to achieve. I made a mistake by buying the wheels before the car is finished, but I do love Lm's.
Old 04-07-2015, 07:00 AM
  #22
1nate7's Avatar
You could always reverse mount the face of the wheel. That would lower the offset about 15mm in which case you probably would want the body mods listed in your first post. It sounds like you have a couple options to get the look you want.
Old 04-07-2015, 08:35 AM
  #23
Site Moderator
Super Moderator
Manga_Spawn's Avatar
If you have the extended studs you have options. The 10mm spacer will work or look into reverse mounting the face. LM's have a lot of customizability since they are multi piece wheels.
johnfrey_s2k
01-29-2016 12:39 PM
Grillo
01-11-2014 02:28 PM
s2k love
02-15-2011 09:36 AM
zbrewha863
04-10-2009 05:50 PM
Amer
09-08-2006 01:31 AM
Quick Reply: The Noob needs help.
