noob here, stretched tire?
hey guys im a noob here, atleast to the tire department, my question for you, and im not looking to be flamed, just wanted to know is, can you stretch the tire on a stock ap2v1 rim? i know stock sizes are 245/45/17 and 225/45/17, but can i fit a 215/45/17 on the rear and a 205/45/17 on the front?
Will +rep this when I re-up.
I'll allow that looks are subjective. But it's down right stupid to do it because it's a safety hazard. Was the tire designed to do that? Nope. Think safety is compromised? Yup.
this "look" was created by professional drifters to reduce sidewall flex and maximize grip two things that improve there safety. That little kids want to bite this "look" is normal.
Ive talked to some tire engineers and most are unconcerned simply stating that you reduce ride quality and can if you have improper suspension settings run out of grip in a corner very quickly.
I like my sidewalls so much that I bought 16 inch rpf1's for my s but I do understand the reason for this.
How does reducing your potential contact patch maximizing grip???
From: The Ultimate guide to Suspension and Handling Part 1, Wheels and Tires
'For all of our poking fun of Hella Flush, and overstreching tires on too wide wheels, stretching tires can improve response by making it harder to get sidewall flex under cornering load. Here the Cyber EVO, one of the fastest time attack cars ever built shows its stretched tires. For road racing we feel that this is not advisable due to the sensitivity to impact damage and de-beading if things are not exactly right but the Cyber EVO shows that this technique can work well. It is a trick that some autocrossers swear by as they need fast response.
Putting the tires on a wheel of the recommended width for the tire is important as well. Putting a wide tire on a narrow stock rim will cause the tread to tend to lift on the edges under side load. If you can’t get the exact wheel width recommended by the tire manufacture for your size of tire, then always err to the wider side if you have the choice. A tire that is slightly stretched on a wide wheel will be more responsive and flex less under side load than one whose sidewalls are bubbled due to too narrow of a rim. Some autocrossers looking for the maximum responsiveness out of their tires will stretch a tire on a rim as much as two inches too wide. When doing this, the rim and tire are more prone to damage and debeading under impact so this is not advisable for street use or road racing where you sometimes put wheels off the track or hit FIA curbs.'
