Non-staggered rims, staggered tires. Anyone doing it?
New to this forum. So I am sorry if this is in the wrong area!
Anyone doing a staggered tire setup on non-staggered rims?
I'm thinking of going 17x9 +42 all around with 225/45/17 in the front and 255/40/17 in the rear.
Also lowered but rolled all around. Any other modifications that I would need to do?
Okay, I figured it would be a fine thing to do, I'm trying to accommodate some space for the front fenders, and keep the staggered setup. I currently have rota grids 17x9 +42 in the rear but 17x7.5 in the front and I hate the look of the flat fronts. I will probably order 2 wheels and tires this week.
I'd much sooner go 235/40-17 on 9" wheels than 225/45-17. Max recommended wheel width for 225/45 is 8.5", they'd be a bit of a stretch on 9". This can accelerate inside treadwear rate if you have some camber. Also, though 235/40-17 would lose you 5mm of clearance on width it would *gain* you 7mm of clearance on diameter/radius. I.e., 235/40 might not be any more likely to rub than 225/45.
Drawback is the lack of tire selection vs. 225/45.
estewkay_frankenstein
06-03-2013 10:28 PM
