newb question
Yes, 18s will fit if the right sizes are chosen and the proper size tires are used. The stock 16" wheels are 16x6.5 offset 55mm in the front, and 16x7.5 offset 65mm in the rear. The 17s on the '04+ are 17x7 and 17x8.5 with the same offsets. If you want something wider than stock, the offsets must be adjusted accordingly. The bolt pattern is 5x114.3. The hub bore is 70.7mm front and 64.1mm rear.
Do some searching and you'll find a wealth of information.
CeleSaga83
03-30-2004 09:35 AM
