New Wheels and Tires set up
Old 08-25-2011, 06:27 AM
That1S2K's Avatar
Default New Wheels and Tires set up
Hey guys, this is my first post so bare with me! I'm going to purchase some rota grids off of a guy and they are 18 x 9.5 all the way around. I can't remember the offset but i'm pretty sure it's +35 all the way around. I'm asking you guys if you think it'll rub with stock suspension setup, and stock fenders. Will i ned some fender work done? Thanks guys!!
Old 08-25-2011, 06:42 AM
1nate7's Avatar
1. An aggressive 18" wheel fitment like that won't look good at stock height.
2. If you run a proper tire size (245+) then you will absolutely need a fender roll even at stock height.
3. Stock AP1 rear wheel is 7.5 +65, will stick out 60mm compared to stock.
If you don't want to mess with fenders and are leaving the car stock height, I would look for something around +55.
Old 08-25-2011, 06:45 AM
That1S2K's Avatar
Thanks man! I plan on lowering it on some coilovers next, so it'll only be on stock suspension for a little while.
Old 08-25-2011, 06:46 AM
FuknS2K's Avatar
get the suspension first.. you'll look like an idiot with those wheels on stock suspension.
Old 08-25-2011, 07:09 AM
That1S2K's Avatar
Yeah I thought about that already, I doubt I'll actually keep the wheels on until I get coilovers. I'll keep it stock till i pick up some coils
Old 08-25-2011, 07:12 AM
1nate7's Avatar
I just want you to be aware what you are getting into. It's certainly possible, people run setups like this all the time but it's not just bolt on and go. I'd go with 225/40 front, 255/35 rear tires. You are going to need a full fender roll, rear bumper tab relocation, and negative camber -3 or more. Rear might need flare depending on how low you go.
Old 08-25-2011, 08:34 AM
RedCelica's Avatar
don't do it...those wheels @ that offset isn't for this car!
Old 08-25-2011, 10:37 AM
That1S2K's Avatar
okay here are the specs.....18x9.5 +22 stretched 235 tires..what you think??
Old 08-25-2011, 11:27 AM
1nate7's Avatar
Even worse. There is no sense trying to make something like that fit unless you are going for hellaflush/fender flare/-5 camber/215 tires. Save those for a 350Z or something that they actually fit on.
The best Grid size available is probably the 17 x 9 +42, new for $750 on Ebay. I'd go that route instead.
Old 08-25-2011, 11:31 AM
afzan's Avatar
you will not only need a fender roll, you'll also need them pulled or some fender flares
Quick Reply: New Wheels and Tires set up
