new owner to S2k wheel ?
i know read the sticky ive been reading and looking and i just want to know if these wheels /tire combo will work on my stock AP 1 2001 s2k without any fender roll etc . if i had to get a narrower tire in the rear im cool with that thanks tom
18" 5x114.3 R2-7's by Rays
18x7.5 +42
18x10 +40
215/35-18
265/35-18
Kumho Ecsta SPT
thnAKS AGAIN
18x7.5 +42
18x10 +40
215/35-18
265/35-18
Kumho Ecsta SPT
thnAKS AGAIN
Ok thanks. I jus teally like the wheel. I think I'll opt for a cheaper set of Drag wheels or maybe the Tsw nurembergs I know on the Lexus forum I get reamed out for buying cheap wheels but they look good and are affordable so I can buy other mods to make it run better
Ok I think this setup might work and the wheel is a little higher quality than the taw etc. I appreciate you guys n girls input as its really daunting and confusing dealing with all the offset issues and size differences when trying to actually buy from a rim company.
Rota D2. 18x8. Front 18x 9 Rear.
Offset + 48. Will that setup work. No fender rolls etc.
Tires I'm thinking. 235 / 45 : 18. Front
255 or 265 / 40 / 18. Rear. Thanks again. Tom
I also found some Rays. Wheels that have plus 50 offset but there only 7 " wide. Front and rear. What's the widest rear tire I could put on that rim without compromising safety or looking stretched Thanks tom
Not good specs, that is a FWD fitment. Widest rear I would run on those is 225.
I couldn't say for sure, not that familiar with stock height fitments. The specs are right at the limit though so the slight difference in width could be the difference between rubbing and not rubbing.
Generally speaking, 18" wheels with low profile tires at stock height is not a good look. I always recommend 17" AP2 wheels for people that want a cheap upgrade that will be an improvement in both looks and performance. No worry about rolling fenders and lots of tire choices available.
