New Bridgestones! RE-71R
Old 01-08-2016, 06:14 AM
  #151
Carbon Blue's Avatar
Originally Posted by s2k4life_az
I currently have AD08 tires (235/40-17 front; 255/40-17 rear) on wheels that are 8" and 9" wide front to back. Do you think I could run 245/40-17 on 8" wheel (lowered at 13" drop with 3.2 camber upfront) without any issues? I'm thinking yes I can. Advise/thoughts?
Here are the comparative specs:
AD08 - 235/40-17
Tread width 9.1"
Section width 9.6"
Overall diameter 24.3"
RE71R - 245/40-17
Tread width 8.6"
Section width 9.8"
Overall diameter 24.7"
what are your offsets on the wheels? Are your fenders rolled? Also, Ive got a few random questions, but have you ever rubbed the front whatsoever at an autox? I would guess with a 245 on an 8 it will bulge even more than your current setup and will rub assuming you aren't rolled. Im at a 13' height from centercap to fender and im still contemplating if I can run a 225 re71r on a stock sized ap2 front wheel. Ive got KW Clubsports and autox regularly and im afraid its going to rub. Ive got stock fenders and do not plan on rolling them for the sake of keeping them original.
Old 01-08-2016, 09:27 PM
  #152
s2k4life_az's Avatar
+54 front and +60 rear with track camber at -3.2 and -3.0 front to rear on non-rolled fenders. The section width is only .2mm larger on the 245/40-17 vs current 235/40-17 so I don't see it rubbing or bulging. The AD08 tires run very square where RE's are more rounded.
Old 01-11-2016, 07:05 AM
  #153
Da New Yawka's Avatar
Originally Posted by Legal Bill
Just a quick heads up for folks. Most of this has been covered in general on this thread, but here are some specifics, especially for those of us on stock AP1 wheels.
1. At 7.6", the 225/50-16 RE 71-R is almost 1 inch narrower that the same size stock S-02.
2. At 7.0", the 205/55-16 RE 71-R is only 1/10th of an inch narrower than the same size stock S-02.
2. There is no wider 16 inch RE71-R listed on the TR web site.
3. The resulting front to rear difference with RE71-Rs is only 6/10ths of an inch versus the original 1.4 inch difference with S-02s.
In general, I also got some information that serves as a warning to everyone. The Customer Service person at Tire Rack immediately asked me if I am tracking or auto crossing the car when I asked about the RE71-R. He said the tire is really designed for racing and that I would experience a very short street life if I used it for every day driving. I asked if it would last at least as long as the original S0-2s or the RE01-Rs which I am using now and he said he didn't know.
WARNING. Several sources have told me that tire manufacturers are rating their tires with a 200 wear factor in order to "meet" the requirements of sanctioning bodies like the SCCA. This is why some tires have been "rerated" from 180 to 200. It wasn't because the manufacturers reformulated the compound. Obviously, some of these tires will wear much faster than other tires of the same rating. The comments above about rocks sticking to the RE 71-Rs tell me you should be cautious if street use is your main purpose for buying them. I may still give them a try and if they wear out in 5,000 miles, so be it.
I was acting like I was ordering OEM Ap1 S02 tires on TR and they only had the narrower "Porsche" edition that they were trying to sell me. Just a heads up for unassuming s02 buyers
Old 01-11-2016, 08:31 PM
  #154
Cheers!'s Avatar
Anyone know when the next Bridgestone sale/rebate will be for 2016?
Old 01-20-2016, 04:42 PM
  #155
dbwy111's Avatar
I want to order these for my CR, but I'm a little worried about them being narrower than the factory tires. What size is best for stock CR wheels?
Old 01-21-2016, 03:33 AM
  #156
ZDan's Avatar
Obsessing over width is misguided. Tire width is a relatively minor player in ultimate grip, particularly in ultimate street grip. I would bet on RE71R even in 205/225 widths over wider 215/255 OEM CR tires in any grip contest. I'd get 215/45-17 fronts with 245/40-17 or 255/40-17 rears. Could go 225/45-17 fronts, but a bit pooched on stock front wheels and taller/heavier, I'd worry about losing steering feel/responsiveness.
Old 02-12-2016, 09:42 PM
  #157
Cheers!'s Avatar
here is how a 255/40/17 looks when mounted to a 9.5" wide rim
Old 02-13-2016, 06:59 AM
  #158
dedonderosa's Avatar
yeah this is my dilemma as well. i current have this setup
17x7.5 48et 215/45/17 dunlop direzza Z1 star specs
17x9 45et 245/40/17 dunlop direzza z1 star specs
and i also have heard these run narrow like you said. im looking to be about the same size as what i have now, but would that mean going from a 215/245 dunlop to a 225/255 re71? or would you think i would be ok with just going with stock ap2 sizes?
Old 02-15-2016, 06:23 AM
  #159
Zivman's Avatar
I just put these on a set of 17x8, 17x9 wheels and a 215 front and 245 rear fit perfect for my liking. I think you would be more than happy with the same sizes on your 7.5/9 setup
not the best pics for showing the tires, but all I have
fronts
[attachment=91164:fronts.jpg]
another pic of fronts
[attachment=91165:fronts2.jpg]
rears
[attachment=91166:rears.jpg]
Attached Thumbnails New Bridgestones!  RE-71R-fronts.jpg   New Bridgestones!  RE-71R-fronts2.jpg   New Bridgestones!  RE-71R-rears.jpg
Old 02-15-2016, 06:37 AM
  #160
VTECJUSTKICKEDINYO's Avatar
Does anybody run these on a two driver auto x car? We tried a set of 225/50/16 on my AP1 for the last event of 2015 locally and found even in 0-5 degree Celcius weather they were getting too hot and required wheel and tire spraying to try and keep the heat out of them. Thinking I might have to go back to the Z2 SS for our car due to the two drivers?
At least they helped me with PAX
Quick Reply: New Bridgestones! RE-71R
