Need Tire Options!
Old 02-02-2011 | 04:44 PM
DesiS2k's Avatar
Default Need Tire Options!
So as the title says. I am dropped currently and running 18x9.5 +50 all around (245/40/18 in front and 255/35/18 rears) with no issues. I want to go a bit more aggresive.
So I was thinking of getting 235 or 225 /40/18 fronts and 235 or 245/35/18 rears on the new ones...
Thoughts?
Old 02-02-2011 | 04:56 PM
ZDan's Avatar
My thoughts:
1. Stick with +50 offset. Less worries and you can run wider tires without rubbing.
2. 245/35-18 up front would be a better fit up front, 245/40-18 are nearly an inch taller than stock, WRONG SIZE.
If you go 245/255, they should both be 35 aspect ratio.
Even 235's would be a better fit in 35 aspect ratio, but there's not a whole lotta selection in 235/35-18.
225/40-18 would be OK up front.
Old 02-02-2011 | 06:07 PM
Dreaming_S2k's Avatar
Or, just put a 5-10mm spacer all around and run 245/35 x4.
Otherwise, agree with ZDan. 245/40/18 is SO tall up front
Old 02-02-2011 | 09:24 PM
DesiS2k's Avatar
Originally Posted by ZDan,Feb 2 2011, 04:56 PM
My thoughts:
The thing is I have 245/40 up front currently and I love the way it looks... Its beefy looking and not stretched. However I would not mind running stretched tires on the new ones.
245/40 on a +50 is equalant to about 225-235/40 on a +35 offest no?
the fronts Im not really worried about. As for the rears, I want to go as wide as possible without any problems.
btw where in Provy are you from? I lived there for 4 years during school ... Im there very very often...
Old 02-02-2011 | 10:31 PM
ZDan's Avatar
You *like* having the fronts taller than the rears, by 0.7"? Put it this way, you now have ~3.35" visible sidewall height up front, and ~3" visible sidewall height in back. Bigger-diameter/beefier-looking fronts with smaller-diameter/less-beefy-looking rears = wrong, lookswise and functionally!
Stretched tires on too-low-offset lip-sticking-out wheels FTL, IMO...
No, 245 width on +50 is equivalent to 215 width on +35 as far as the outer tire sidewall is concerned. Move the centerline of the wheel outboard by 15mm, and you reduce the tire width you can run without rubbing by double that, 30mm. Lower offsets + skinnier tires = WTF
If you want to go as wide as possible, you want to keep +50 offset, which will allow 20-30mm wider tires vs. +35 offset (slightly less than 30mm wider due to the wider size being a bit taller as well for the same aspect ratio, which would be the same /35 for typical rear widths).
I'm just over the line in Pawtucket, near the Hope St./East Ave. end of Blackstone Blvd, soon to be moving to ATL, though. I'm usually up for a beer or three...
Old 02-03-2011 | 10:05 AM
DesiS2k's Avatar
so what tire sizes would you suggest up front and rear without issues?
And def let you know next time im in Provy...
Old 02-03-2011 | 11:03 AM
ZDan's Avatar
Yeah, hit me up when you're in providence!
If you want "more aggressive", you might go 255/35-18 all around. If a taller 245/40-18 isn't rubbing up front, a shorter but wider 255/35 is probably going to clear, too.
Maybe 255/35-18 fronts with 265/35-18 rears? No guarantees you wouldn't start to get rubbing in back though, with 10mm wider and also taller rears...
What kinda tires are you considering?
Old 02-03-2011 | 11:24 AM
Jim@tirerack's Avatar
Former Sponsor
I would say the 245/35R18 and 255/35R18 rear would be the way that I would go. The 245/40R18 with the .7" difference can throw off the anti lock brakes.
Old 02-03-2011 | 01:44 PM
This.
Old 02-03-2011 | 08:09 PM
DesiS2k's Avatar
blahhh...Went with a set of Work Kais 17x9 +44 I can get as beefy tires as I want now
Thanks for all your help guys!
Now just one more...for the rears, with the works, will a 245 45 setup fit or do you think I should get a 255 40 for a beefier look. Obviously the 265s are wider but froma side angle, the thicker side walls look beefier no?
Once again...Thoughts?
