Need tire advice
Max and Extreme Perf tires, 215/45 F, 245/40 R
Max and Extreme Perf tires in 235/40 F, 245/40 R
This fitment is at your own risk!
Max and Extreme Performance, 245/40 F&R
245/40's all around, also at your own risk!
The Dunlop Direzza Star Specs are getting rave reviews.
Bridgestone RE11's are likely the highest-performance real street tires you can get right now.
Hankook Ventus RS-2's are very good tires for the money, I have a set on my car. They are great street tires and are also up to track usage. Lower performance than the RE11's and Star Specs, but definitely a more serious performance tire than the S.Drives.
Kumho Ecsta XS are probably higher-performance than the Hankooks, at not much more $$$.
It is worth your time to root around and study the consumer reviews and test results for different tires in the Tire Rack website. It is a FANTASTIC resource!
That would be 245/40's all around!
You payin' attention?
As far as "wider tires = more grip", it depends.
At the track, in the dry, with tires fully heated up, wider is pretty much better (up to a point).
On the street, tires not fully warmed up, and/or in the rain, wider is not "better".
What are you using the car for? If you're not tracking or autoXing it, I wouldn't worry about "wider", I'd go:
215/45-17 front, 245/40-17 rear (stock AP2 sizes).
If you're SURE you have clearance and won't rub, you *might* consider 235/40-17 fronts, or *possibly* 245/40-17 fronts. But the extra width (and weight) up front can actually conspire to make the car feel more sluggish and less nimble (although ultimate grip levels would be higher).
If you *are* tracking or autoXing it, then you got the wrong wheels. you can run much wider tires with higher offsets, and also you'd want wider wheels to run 255+ width in back, or even all around (8" = 245/40 max recommended width).
The wheel can take a wider tire. The question is how wide can you go before you rub.
Without fender rolling, the "Wheel Fitment Guide" stickie (worth having a look at) recommends +48mm minimum offset for 215's, +53mm for 225's, +58mm for 235's, and +63mm for 245's.
*IF* you were running 235/45-17's (taller than stock) all around, you *should* be able to run 235/40-17's (which are shorter) up front with no problems. It is possible that 245/40-17's *might* work.
225/45-17's would work up front as well, but personally I find that they give a "big fronts/little rears" look when used with 245/40-17 rears.
With those fenders, I would think you *should* be OK with 245/40-17's up front, but I can guarantee nothing!
You could dial in some negative camber if you rubbed. You can easily run 2* and more on the street for more clearance without serious inside wear issues.
