Need some tire advice
So:
my MY'02 has 12K miles, and the insides of the fronts are getting quite worn. The rears are ok. All original rubber. I figure I will need new tires soon. I love the OEM equipment, but would like to get more miles out of the tires, even if I have to sacrifice performance a little. Someone suggested 03's. Am I likely to get significantly more mileage out of them (like twice?). I mostly commute, with some occasional spirited driving on weekends. Will the size with these be the same as with O2'S?
Any advice appreciated, thanks.
Former Sponsor
You won't get double the tread life out of any tire on this car. The S03 should last longer given the same driving characteristics but I would doubt more than 15 to 20%. If you go to the S03 I would recommend the 205/55R16 front and 245/45R16 rear.
The longest tread life tire I would have would be the Dunlop SP5000 and they are an all season tire. You would loose quite a bit of the performance though.
If I can help let me know.
Thank you
Jim 800-428-8355-364
Thank you
Jim:
thanks for the response. Besides the longevity of S02's, they obviously don't handle well in the rain. Would S03's handle better under wet conditions?
Originally posted by boiler
That's odd, my OEM S02's worked very well in the wet until right before they wore out (hydroplaning).
Avs2k, Have you had any other tires on your car? My OEM tires didn't do anything like what you're describing. The amount of grip they had in the rain was incredible. The only problem was the way they made the grooves in the tire. I was discarding the tires (rear) before they got to the wear bars, because they were prone to hydroplaning, due to the grooves becoming smaller.
I think that it's starting to make sense to me. I was changing mine at around 12,000 miles. It just sounds like the rear tires are worn out, even though you will see tread just above the wear bars, most likely. Was your car always handling like this when it was wet outside, even when the tires weren't worn out?
Normal to me would be great traction in the wet or dry from new to around 12,000 miles. Once you wear the rear tires almost to the wear bars, the traction in the wet will be gone and it's time to replace the rear tires. It's always a good idea to keep the front and rear tires the same brand and model. Otherwise, you may have a real handful when it rains. Different tires will always have different levels of traction and mixing them is asking for trouble.
Does this make any more sense to you?
Bob
Bob
the description does make sense to me, but the behavior i am describing is not new. it has always made me scared in the rain. sounds like your experience is very different, huh?
av
