need pics of rims on s2000
my tires are about to blow and want to get rims and tires at the same time so if you can send me pics that would be nice
good luck getting rims and tire in one day. your best bet is to scour the local and for sale forum and see if anyone is selling a set in your area. Not too many rim stores will have rims for our car as it is best to have a staggered set-up (narrower wheels in front and wider in the rear. Also the offsets needed aren't too common. From what i read you will need over a +45 in the front (depending on wheel width) and over a +50 in the rear (again depending on wheel width). Your better off just getting new tires for the time being and taking your time to find a set that you like.
Get tires that can be transferred to your new rims when they come. However, this will restrict you to 17" tires and if you later decide to go 18" or bigger, those tires will be wasted. If you go with 17" rims later, make sure they are meant for this car and have the correct offset and widths. With this in mind, get tires that are sized as follows:
front - 225/45/17
rear - 255/40/17
Of course, if you ever lower your car, these may not work. You must decide now what your short and long term goals are for your car as the decisions you make today will affect those you might make later.
