Need new rear tires but can't decide
I've been reading a ton of posts on here and I can't decide what tire to go with. Right now I have 13,000 miles on the car with the factory tires. The rears are have no tread left. The only thing I don't like about the RE050 is that the tread life is horrible, 13k max! Here is what i'm looking for. BTW, I live in Miami.
High Dry Traction and High Wet Traction
At least 15-20k of tread life
No more than $180/tire
I've been looking at Yokohama, Bridgestone, Cooper, and Falken
And I drive semi agressive
thanks
thanks
You really should match the rear tires to the front if you are getting new replacements. Unless you are an engineer and can calculate the differences safely. I would ask Jim the advisiblity of mixing and matching different brand and type tires on an S2000.
Our car is not very forgiving if you upset the balance. Know about power oversteer?
Or simply replace all four at once.
RE-050.
If you're going to replace all 4 and want to go cheap, get Kumho MX.
But the "best" tires are going to be an RE-050 or an Advan Neova.
I'm not trying to sound negative, but you're not going to get a tire that wears well and still have high grip. To get 20,000 miles out of rear tires you're going to have some tires that are no where near as sticky as the OEM set.
