Need help with wheel/tire
Ok, so I realize that my previous offsets were all wrong, so here is what I got:
wheel: front 18x7.5 +42; rear 18x8.5 +47;
tires: rear 255/40; front 225/40
Now my question is will this rub? Should I go with a 215/40?
you'll be fine with a 225, your rears will rub depending on your ride height, your fronts should be fine, you may need to modify the fender liner/ run slightly more camber but that's it. Rear all you would need is more camber.
I ran 18x9 + 55 all around with 225/255 and I had f -1.5/r -2.5 camber and cut our my fender liner in the front
