NEED HELP TIRE SIZES
I would not recommend those sizes. First they are shorter than stock by about 1/2" on the front and with the 225/40R18 in the rear can throw off the anti lock brakes. The other thing is they load capacity is lower than the stock tires. The last thing is if the car is not lowered it will not look right with more wheel well gap because of the shorter tires. I would do 225/40R18 or 215/40R18 depending on the offset of the wheels and then a 245/35R18 on the rear and run more negative camber. Why run such a wide wheel and such a narrow tire.
buy wheels that fit the car
all-trick'd-out
04-03-2004 07:04 PM
JONJOS79
02-27-2004 06:42 PM
