Need help! TE37
Need help! TE37
Hi guys! I am looking at a set of used TE37, don't know if it's a good setting for S2000
Front: 17x8.5 +40 235/45/17
Rear: 17x9.5 +40 255/40/17
Can anyone tell me if this is a good setting?
Thanks!
Thanks!
You can make that fit but it's aggressive and will require quite a bit of fender work. It will only look good if you are lowered and running a decent amount of negative camber.
Former Sponsor
You have to decide if it is worth fender modification. The front size tire is also not very good. I would stay with 225/45R17 on the front.
If I can help let me know.
