need help choosing new wheels
Old 09-03-2015 | 06:24 PM
sureshot1234's Avatar
Default need help choosing new wheels
back when i go my 2005 s2000 the previous owner had changed the wheels to some rays wheels and they only handle 215s front and rear and its always bugged me i need new tires on the rear now and dont want to put smaller tires than stock on it so i need to get new wheels. i pretty much have no budget in a bad way like no money lol but am saving and have been saving this year. im looking for the lightest yet strong and cheapest wheels i cant get for the car that dont require messing with the fenders the car is lowered on neuspeed springs i believe i need to change the suspension out as well and plan to go with a coilover havent decided that either.
what wheels do you all recommend for me?
also there are some pretty cheap high offset square setups but dont know what i would need to offset the increased grip in the front to keep the handling right i have heard it changes things
Old 09-03-2015 | 07:03 PM
Chuck S's Avatar
Hard to beat the OEM wheels. They're not the lightest but are made by Enkei. There are good reasons these came with staggered wheel setups. Set of 4 reconditioned AP2V1 wheels is about $600. No messing with anything with these.
-- Chuck
Old 09-03-2015 | 07:19 PM
-- Chuck
where can i get them reconditioned? i do like the look of the ap2 v1 wheels also how would i know they are real and not replicas everything i have read says replicas are quite a bit heavier
Old 09-04-2015 | 03:04 AM
Chuck S's Avatar
I bought a set of four (2 front, 2 rear) AP2V2 wheels for my '06 last summer from Allfactorywheels dot com. These are reconditioned, not brand new, but look very good. Probably $700 with shipping looking at their website this morning.
-- Chuck
Old 09-04-2015 | 04:46 AM
RedCelica's Avatar
If you go square you will seriously want to upgrade the front sway bar as well. I run TR 17x9 +62s, but if doing it all over again the Kosei wheels look like the best bang for the buck and under 17 lbs a piece. I love having 255s all around, but I also have a comptech adjustable sway set to full stiff.
Old 09-04-2015 | 05:53 AM
-- Chuck
thanks for the advice and link i will check them out
called them and they dont have and refurbished wheels left just replicas
Old 09-04-2015 | 05:56 AM
would i have to roll or modify the fenders to run a square 245-255 setup i have managed to induce understeer twice since owning the car so a wider front wheel and being able to get full warranty on tires would nice. also i know it depends on tires but does running affect wet traction since it decreases pressure per square inch?
Old 09-04-2015 | 06:07 AM
RedCelica's Avatar
As long as your offset on the wheels is greater than 60 the only thing you'll want to do is bend up the two top-most bumper tabs a little. I just used the handle of a mallet to do so and it worked fine. I drove home in the pouring rain on RS3s and did just fine. Running a tire like the RE71R would even be better. Some people report increased tramming with a 255 up front, but I havent had any real issues. Again, if you go square you will want to upgrade the front sway. This is pretty important.
Old 09-04-2015 | 06:10 AM
Originally Posted by sureshot1234' timestamp='1441374968' post='23736955
[quote name='RedCelica' timestamp='1441370810' post='23736863']
[/quote]
i will be getting pilot super sport tires when i get the wheels had z1 star specs before would swift front and rear sway bar kit be a good choice?
Old 09-04-2015 | 06:19 AM
RedCelica's Avatar
Again...you only want to upgrade the FRONT. Swift is a bad choice because the front bar is actually not as stiff as even a stock ap1 bar (see here: http://www.swiftsprings.net/products...tabilizer.html )
Review this thread: https://www.s2ki.com/s2000/topic/908...y-bar-options/
IMO, you'll want at least a bar that will do 500 lbs, but 600-700 would be great for when you get coilovers.
PSS are awesome, but only come in 245/40s, no 255/40 is available, which actually might be a good thing since you're lowered.
This would be a great option, and quite affordable too: http://shop.moddiction.com/Moddictio...ay-bar-068.htm
Quick Reply: need help choosing new wheels
