Need to find rpf1 setup.
Old 02-01-2011, 08:19 PM
JDMQuip's Avatar
Originally Posted by Moddiction,Feb 1 2011, 08:59 PM
I want the concave rpf1's I think.
So maybe just 17x9+45 all around.
Would love to be able to rock 225 front and 265 rear.
Definitely don't want to have more than -3 camber in the rear and -1.8 or so in the front.
Then I would get the 17x9 +45 on all 4 corners. I was running -4 camber rear and -2.5 front with my 17x9 +45 front and 17x9.5 +38 rear with 245/40/17
Old 02-01-2011, 08:22 PM
Former Sponsor
Moddiction's Avatar
Ok cool. So up front would be fine with the 17x9+45 with a 225 tire on it? Or too much of a stretch? Like the concave rpf1's much more so want the 17x9's.
Would the 265 fit in the back ok you think?
Old 02-01-2011, 08:30 PM
JDMQuip's Avatar
Depends on your use. If you plan on tracking the car you can do 255/40/17 all around, as I did. If you're worried about fitment then you can technically do a 225 but I wouldn't. My thought is this...you have to do light fender mods anyways so you might as well get meaty tires. 245/40/17, 255/40/17 on all corners.
You can do a 265/40/17 but IMO it's a bit overkill. My friend has 265/40/17 on his RPF1's and it looks taller due to the higher sidewall.
Old 02-01-2011, 08:35 PM
Former Sponsor
Moddiction's Avatar
Well not tracking my car. Just daily driving it really. From what I hear getting rid of the staggered will give more of an oversteer feel since I lose the grip advantage in the back no?
That is the reason I would like to keep the stagger for the most part.
I am already rolled up front and in the back so if I could fit a 225 up front without rolling anymore that would make it much easier as well.
Old 02-01-2011, 08:40 PM
JDMQuip's Avatar
Yeah, you have a little more oversteer but nothing noticeable unless you're tracking it. at least with 245/40/17 on all corners you can rotate your tires and save some cash.
You'll be fine with a 245/40/17 all around and -2 Front and -2.5 Rear.
Old 02-01-2011, 08:44 PM
Former Sponsor
Moddiction's Avatar
How about 255? Main reason I am wanting to change wheels is to be able to run a wider tire since I only have 17x8 wheels all around now.
Getting re tuned for around 400whp in a month or so, so wouldn't mind a little more traction.
Old 02-02-2011, 04:53 AM
Dreaming_S2k's Avatar
IMO, this is the kind of setup I think you're looking for:
That's 17x9 +45 all around, 245 front, 255 rear.
Old 02-02-2011, 04:55 AM
1nate7's Avatar
I am running 225/255 on 9" +45. The front is stretched but not that noticeable or extreme. If you go more aggressive with wheels, you are just going to be limited by fender clearance instead of your current wheel width issue. You could do 265/40 rear but I think a 255/40 is much better fit and look with a 225/45 front.
Old 02-02-2011, 08:20 AM
Former Sponsor
Moddiction's Avatar
Those both do look pretty sweet.
What are your alignment specs and what sort of fender work done?
Old 02-02-2011, 09:31 AM
s2sik's Avatar
by the sounds of what you are looking to accomplish i suggest 17x9+45 x4 with 255 star specs. the standard rolls and tab relocation should be good. i would start at -3 camber, max caster, zero toe for the front, -3 camber, 1/8 in toe in the rear.
Quick Reply: Need to find rpf1 setup.
