Need advice
Need advice
Curious to know what would be a better setup. I am looking at a set of 17" wheels that are available in 7 or 8 inch for the front with a 48mm offset. The rear is a 9" with a 63mm offset. Will the 8" work up front without rubbing or should I stick with the 7" ?
Former Sponsor
I have seen the 17X8 ET48 with the 225/45R17. It is tight but they do work. WIth the 17X9 you would be in a 255/40R17 rear. The wider tires in the front do work the best.
If I can help let me know.
