MY05 OEM Tire Size
Old 01-07-2009 | 08:31 AM
mjschrage's Avatar
Thumbs up MY05 OEM Tire Size
I was thinking about switching up my tire size to 225/45/17 fronts, 255/40/17 rears to help fill up the wheel well a little better to give the illusion that the car is sitting lower than it really is.
So the big question is; will I lose out on performance some where?
I know the tire will be heavier= more curb weight= the obvious!
Will my handling be affected?
Will I have correvt odometer readings?
Thanks all!
Mike
Old 01-07-2009 | 10:03 AM
1nate7's Avatar
Is that rear size a typo? 255/40/17 is the typical +1 size in the rear.
Old 01-07-2009 | 11:31 AM
mjschrage's Avatar
Yep...I was thinking about another setup as well. Thanks for pointing that out!!!
Old 01-07-2009 | 12:03 PM
1nate7's Avatar
There will be no problems if you run a 225/45 and 255/40 combo. It usually makes the speedometer more accurate because they tend to read slightly faster than actual speed with stock sizes. This really is a very small tweak and the weight and handling difference will be minimal. Just don't do anything crazy like a 55 series sidewall, that would cause some issues. It probably won't give you the look you want, but there isn't really any downside to that combo.
Old 01-07-2009 | 12:58 PM
Jim@tirerack's Avatar
Former Sponsor
The only way you will loose performance is if you choose a tire that is not as high performance as what you are taking off.
If I can help let me know.
Old 01-08-2009 | 12:48 PM
EOE's Avatar
EOE
But will that set up really make the car look lower?
Old 01-08-2009 | 02:04 PM
mjschrage's Avatar
it would I think by about a 1/2", its something....
I have decided to go with the OEM wheel fittment Direzza Sport Z1 Star Spec.
Many people feel that going with a larger tire on a smaller wheel will make the performance in the rain worse; the only reason would be if the tire lost surface traction due to the larger tire on a smaller wheel, and this would also affect handling, giving the car less traction to the ground (RIGHT) If this is true then many people have made a grave mistake when purhasing their setups (it all makes sense )
Old 01-08-2009 | 02:07 PM
EOE's Avatar
EOE
I am really not sure if going 255 will make things worse in the rain that just doesnt sound right. Can some one elaborate that theory?
How about keeping 215 in the front and 255 in the rear.
Old 01-08-2009 | 02:14 PM
mjschrage's Avatar
you would look like you were driving on a down slope every where you go! I have thought about doing this myself but you should keep the ratio between the front and rears closer.
Old 01-08-2009 | 05:25 PM
EOE's Avatar
EOE
CR Seems to have no issues looking like it's on a slope apparently....
Front Tire Size, P215/45WR17. Rear Tire Size, P255/40WR17
