My current setup, small issue, input welcome!
Old 01-16-2012 | 05:45 AM
newyawkballa's Avatar
Banned
What happened with this situation? I finally got my 18" Comps and I need to lower mine, not sure what springs I'm going with. Probably same size but different brand tires.
Old 01-16-2012 | 07:05 AM
[DT]'s Avatar
Hey NYB!
You know, it just stopped at some point, I don't know the alignment "settled", or some other external factor changed, or maybe it was just a tiny bur on the fender/tab somewhere that rubbed off.
About a year ago I went with some new tires, Hankook Ventus V112, same size as the original tires: 225/40-18 (f) 255/35-18 (r), and I've been in some situations with extreme suspension compression (the intracoastal bridge on JTB for local folks ... ) and zero rubbing.
Old 01-16-2012 | 07:31 AM
Banned
How do u feel about your brand of springs? I have to lower my S2k, and looking to get rid of the wheel gap. Stiff/ rough riding isn't a problem for me. I was thinking Eibach Pro-kit springs but a 1 inch drop might not be enough. I will probably get the Koni Yellows one day.
Old 01-17-2012 | 09:06 AM
[DT]'s Avatar
I like the ASD Espelir springs quite a bit, perfect amount of drop, as in much lower vs. OEM. It looks "purposeful" since it doesn't require any kind of overdone alignment, stretched tires or whatnot. They're also a progressive spring, so it mirrors the OEM springs quite a bit, a touch stiffer, a good bit lower. Price is right, and matching them up with Konis is a great idea if you don't want to go full on coilover setup.
FWIW, I've heard some folks bottoming out (creating a little bouncy rebound) and some say aftermarket springs can cause premature failure on the OEM shocks.
landapanda
09-01-2018 04:00 AM
JSWhaler
04-13-2010 08:53 AM
Moddiction
04-01-2010 09:03 AM
FREEK
05-30-2009 08:48 PM
teanza
09-26-2008 03:58 PM
