my bbs wheels offsets still rubbing a lil... Help!
I'm on koni shocks and teins springs with my bbs lm wheels offset. Front 18x8 + 40 225/40/18 Rear 18x9 + 40 255/35/18
I roll my rear fenders its still rub a lil when i hit a dip or slowing on bump. So ya think i be better off with 245/35/18 ? some of my friends think it be better with 235/35/18 tires for more safe for my tires not to rub any more cause of my offset wheels
Try alittle more negative camber. If that doesnt work, then get skinnier tires. I may be interested in the 255s depending on what kind they are if you end up with new tires.
Sent using free Tapatalk - Android FTW
First of all, figure out how much more clearance you need. 245 width tires are going to give you 5mm more fender clearance than 255 width tires. I would definitely try more camber first though.
