More uneven front wear than usual?
I have an 03 with almost 17k, and I believe the front tires are original S02's but the PO might have had them off the car for a while. I thought I had a lot of wear left on them until I parked with the wheels turned out one day. I am planning on replacing them with OME S02's from TireRack.
I have seen others comment that the front tires on s2k's wear unevenly towards the inside edge, but I wanted to make sure that the wear I am seeing is within normal range This is the driver's front tire so inside wear is on the Left.
The pictures don't entirely do justice - the tires are almost bald on the inside, while on the outside there is a lot of tread. A good comparison is the short grooves, on the inside they almost lose their shape, on the outside they have a lot of tread.
So my question - is this within the normal wear range, or should I go for an alignment too, and if so what flavor of alignment?
Thanks,
JD
Thanks,
JD
