Mixing manufacturers
Old 09-27-2003 | 09:51 AM
jdecicco's Avatar
Default Mixing manufacturers
I am looking for a highly-rated all-season set. The main consideration is better tire wear, then to a lesser degree snow handling ability.
My rear OEM S02's lasted 10k miles, then my second rear Yokos also lasted only 10k. The Pirelli P Zero Nero M+S look good for the rear (245/50 WR16 SL), but I don't see a well-rated Pirelli pair for the front.
Is it okay to mix mfrs on the front and rear? Also, anyone have suggestions for a good all-season set?
John:
Old 09-28-2003 | 07:17 PM
mas's Avatar
mas
First, don't mix tires. It's been discussed here many times (you can do a search) and not considered a good idea.
Second, all seasons won't be enough in snow. If you plan to drive the S in VT winter then you need a set of 4 winter tires like the Blizzak LM-22, Pirelli 210, etc. You may even consider hardcore snow tires like the WS-50 or Toyo Garit HT, depending on how well the streets are cleared in your area.
speakeasy2009
11-20-2012 05:07 PM
FormulaStwoK
11-08-2010 10:11 PM
gdub
12-10-2009 12:32 PM
ROGUE3308
11-18-2003 10:15 PM
navybeaN
10-29-2002 04:42 PM
