max rear ap1 tire size
Old 03-06-2015 | 03:14 PM
Jmeares24's Avatar
Default max rear ap1 tire size
Trying to figure out what the widest rear tire size i can safely run on my stock ap1 rims is for max traction. Note the tires are going to be drag radials and also fenders will be rolled…
Old 03-06-2015 | 04:21 PM
s2000Junky's Avatar
Well if your doing drag radials then obviously handling isn't important to you, its all about strait line/drag. So id say your best option is 255/45/16. If you want more gear then up it to a 255/50. Run as little camber you can dial in the rear for the most contact patch, you can use air pressure to dial in the best squat.
Its all fundamental drag principals, regardless of the car. But on the stock 7.5" 16" wheels I think your limited to 255.
Old 03-10-2015 | 10:17 AM
Jim@tirerack's Avatar
Former Sponsor
I am not sure of any tires ina 255/45R16. The issue with the 255/50R16 is they are over 1" taller than stock so they will change the gear ratio. The best that I have seen in the 16" is a 245/45R16. If I can help let me know.
mason.whitlow14
01-03-2014 07:14 AM
jetmagnum
12-29-2010 11:06 AM
josserman
01-19-2010 03:37 PM
Back S2k
07-24-2009 06:35 AM
BSeriouS
02-20-2006 10:49 PM
