man this is hard...
man this is hard...
hey does anyone know if rota slip streams, 16X7 all 4 with offset +45 all around will fit on our cars? im not planning to lower my car so i dont think i have to worry about rubbing, but do you think it will fit on ap1's? i have found some slipstreams with azenis tires for 300 ONLY so if this works than i'm gonna buy it. thanks for all the help!
I ran 16 X 7, 44 offset and staggered winter tires for years. They'll fit. No rubbing, but the handling will suffer because of the staggered tires on non-staggered rims. If you run the same size tires all around, the handling will suffer even more.
Oh, this is assuming the bolt pattern is 5 X 114.
Originally Posted by s2kboii,Apr 5 2006, 09:06 PM
so what size should be on the back? and on the front do you guys reccomment the most? thanks for the help guys!
If it's rims, you didn't say you had a choice of a different size for those rims. You seem to indicate that "16X7 all 4 with offset +45" was all there was for a choice.
The "correct" size would be what the OEM numbers would be.
16 X 6.5, 55mm offset front with a 205/55/16 tire.
16 X 7.5, 65mm offset rear with a 225/50/16 OEM tire or a 245/45/16 non-OEM tire.
