Lugnuts
Old 05-10-2005 | 11:27 PM
jdnissanz's Avatar
Thumbs up Lugnuts
When I bought aftermarket 18" wheels with a 48 offset what type of lugnuts can I get any special sites with good prices and anyone know the exact sizes?? Or can I or should I use the stock lugnuts from the stock rims on my S2000...BTW anyone know where black lugnuts for aftermarket wheels could be purchased???
Old 05-11-2005 | 07:14 AM
deepee's Avatar
evasivemotorsports.com
depending on which rims you have, you can fit stock lugs...there are other alternatives with keys/locks such as muteki, kyokugen (sp?), gorilla etc etc.
Old 05-11-2005 | 08:43 AM
03_AP1's Avatar
many aftermarket rims require tapered conical lug nuts, and the stock acorn nuts won't work.
Old 05-11-2005 | 10:54 PM
jdnissanz's Avatar
Hey guyz another quick question which kind of lugnuts can I get can I get the closed ended lugnuts or are the open ended the way to go?? I am ordering form evassive sooo I need to know soon thanks in advance!
Old 05-11-2005 | 11:05 PM
MaxGeek's Avatar
You can get closed ended lugs. I would recommend McGard Tuner Lugs and McGard locks. You can get theem from amazon.com. The powder coat is much nicer then those of muteki, its shiner and thicker. Of course they cost more though.
Old 05-12-2005 | 08:39 AM
rijowysock's Avatar
oem= acorn (conical)
aftermarket are tapered
which means dont use ur oem nuts they have rounded end. aftermarket wheels have a 60degree taper so they have more surface area on the wheel.
anywho.. open ended/closed dont matter it just depends what u like. i prefer closed because they dont cause any errosion on the studs... esp if u live up north open ended rnt good to have in snow/salt etc
Danwolski
04-22-2012 02:59 PM
AP1_S2k
09-26-2007 08:11 PM
AndyThomason
01-23-2007 09:44 AM
DannyCoolBeans
01-10-2007 06:36 PM
460cidpower
03-20-2006 03:53 PM
