Lowering
Old 11-25-2005, 05:29 PM
SB Global's Avatar
Default Lowering
Hey All,
Has anyone lowered their S 2inches on stock wheels preferably, any problems and pics would be appreciated.
Old 11-27-2005, 08:59 PM
SB Global's Avatar
Hmmm no one?
Old 11-27-2005, 09:01 PM
BlackNightmare's Avatar
2 inches..i lowered mine and these are suppose to lower 1.3 but they haven't settled yet. 2 inches the only problem i HEARD around here is needing a camber kit and maybe an allignment
Old 11-28-2005, 11:27 AM
spa-zz's Avatar
MAYBE an alignment?
Old 11-28-2005, 08:44 PM
i think so..but i think they said thats only if u mess with the control arm. that could mess up the alignment. but I installed my springs myself even though they were along 1.3 inches drop and the alignment is still perfect. So I take it back but you'd have to ask someone who's dropped theres that much.
Old 11-28-2005, 08:52 PM
RT
RT's Avatar
how do you know "the alignment is still perfect"?
Old 11-28-2005, 08:59 PM
the alignment is good enough for me, i can take my hands off the steering wheel and the car goes straight for a long time just like it did before i installed the springs. To me thats perfcet. i'm not going to take it to the shop to check the alignment..if it goes bad then i'll get it aligned, but so far its perfect. the only bad thing is the camber is just a little negative that it used to be..but thats normal when lowering. i might get a camber kit but we'll see.
Old 11-29-2005, 12:10 AM
CrazyPhuD's Avatar
actually you alignment is almost certainly a disaster. You'll be running a mixed up combination of camber and toe, your car may track straight when you release your wheel, but it's performance at the limit will suffer. Plus you will eat tires like there's no tommorrow.
Old 11-29-2005, 01:25 AM
soooo what should i do? get an alignment? or just a camber kit? or both?
Old 11-29-2005, 06:45 AM
spa-zz's Avatar
Get an alignment!
Your toe settings front and rear and guaranteed to be all out of whack after lowering. The fact that the car tracks straight with your hands off the wheel has nothing to do with it.
When you get your alignment, make sure they check camber. If you can't meet the camber specs, you can just live with burning up tires, or you can get the camber kit to fix it properly.
Quick Reply: Lowering
