Lost Wheel Lock key
Lost Wheel Lock key
Just realized that the last place that installed tires on my wife's car never gave me back the wheel lock key. The wheel locks were McGard, I think (that's what TireRack sells, right?). What to do?
If you cannot get a new key (might need to take a closeup pic of the pattern), then buy a new set of locks with new key. You'll have to get a tire shop to take your old locks off using one of their "universal" lug sockets. The old nuts will most likely be unuseable after.
If they are McGard you can get a replacement key if you have the code# which came with the package.
If you don't have Code# and they are McGard then you have to go the long route...
You'll have to get the stud cut off which have the locks on them and replace the stud and get a new set of locks sorry to say they are doing the job they were meant to do.
A detailed digi pic won't work because the slightest error and the key won't work.
[QUOTE]Originally posted by xviper
if you have access to air tools you can use a air hammer used to cut thourgh sheet metal. first get a grinder and cut a notch on one the the side and use that as grip for the airhammer but go slowly cause if you slip it might hit your rims. we use this method all the time and the bodyshop i work at. if not some auto part stores sell lug nut removers for striped lugnuts.
