A little overwhelmed.....
Hi all, I'm really interested in getting some WORK Cr Kais for my new S, I'm just a tad overwhelmed by all the info and everything that is needed to pick the right wheels with correct offset etc. Right now I have stock everything and what I'd like to do is keep everything stock and just swap in the new wheels, what is the best combo of wheel size and offset to get for what I want to do?
Thanks,
Thanks,
Thanks,
Thanks,
Not even sure if these offsets are still available so you'll have to contact the vendor. The +40's offsets give a nice aggressive look usually without mutilating your fenders and preserving handling. If you don't want to do anything at all to your fenders, you should probably look at wheel with higher than +50 offsets. Hope this helps.
That's very helpful, thank you. I think it will look great lowered and I wouldn't mind dropping mine a bit, but I simply can't, I scrape (minimally) on my driveway at stock height so I can only imagine what I'd do once lowered.
Funny thing is I used to scrape occassionally with my oem lip with a carbon splitter but never have with the crlip with the sfactors steel splitter.. If i lower it it will be an inch or so just for looks > I dont like the slammed hellaflush look at all cause i dont want to worry about bottoming out anywhere and have to change my driving habits due to that..
Can you pull into your driveway at an angle or something else?
http://www.griotsgarage.com/product/...ortby=ourPicks
GyorsS2000
Member S2000 Classifieds and For Sale
01-21-2010 05:48 PM
