learning wheel fitment
looking into gettin some rims. and i just want to hear other ppls opinion.
i read thru the guide... and these numbers fall into the category.
FRONT
17x8 +48 215/45/17
REAR
17x9 +42 245/40/17
i dont know how would this set up look like.. if anyones running this.. im jus wondering if i can PLS. see em, it' be really helpful.\
any inputs would also be informative.
thanx!
FRONT
17x8 +48 215/45/17
REAR
17x9 +42 245/40/17
thanx!
Former Sponsor
The 17X9 is aggressive and would take some work on the fenders to fit.
Maybe some negative camber as well. I have even had 17X8 45mm offset rub with the 245/40R17.
This is 8" +45 and 9" +45 with 215/45 and 245/40. Your fitment would be sunk in 3mm in front and stick out 3mm further in rear. You would need a roll for sure in the rear if you are lowered at all.
Originally Posted by 2k_s2k,Oct 4 2010, 06:21 PM
so basically, my offsets are switched??... i should have a +42 in front and +48 in the rear... rite?
nickoces2k
11-02-2017 09:36 PM
molotovsoldier
09-22-2015 08:27 PM
08s2000CRbackinblack
02-05-2009 03:40 PM
