Jim, I need Kumho MX tires
I was checking on tirerack and they have the fronts in stock, but i need 245/50/16 for the rear's and they didn't have them.. any idea of when they will?? or does kumho even make them in that size?? or do u have something else u would recomend?? thanks..
You are getting wheels that are slightly wider than stock (8in vs 7.5in). There's no reason to go with a taller sidewall. If you want to go with 245 section tires, they should be 245/45-16.
