Jim, I need a couple of quotes
Jim, I have a couple of questions. First, I will need to replace the rear tires soon. I currently have the OEM s-02. My front tires are still ok, plenty of treads left. I'm thinking of either Yokohoma AVS es 100 or Bridgestone RE750. What are the prices for these rear tires? Second, can I still keep the front tires stock and replace the rear ones with either brand above? Would that create any problem? What should the offsets be for the rear tires if they're not OEM? Thanks
The ES100 would be 97.00 each and the RE750would be 125.00 each. I would not recommend to mix them with the S02 on the front. You will have a lot better wet handling rear and better dry handling in the front. In an emergency situation it could be scary. You would have under steer in the rain and oversteer in the dry.
The tire size would be 245/45R16 rear.
If I can help let me know.
Thank you
Jim 877-522-8473-364
Thank you
