i need help asap
i need help asap
anyways im about to lower with a swift front .8 and rear 1.0 inch.
i am running 225 and 255 17 front and rear.
wheels size 17 x 7.5 +45 front
wheels size 17 x 8.5 +50 rear
my fenders are not rolled
so my question will this fit. without any rubbing
i hoping not since im not drop really low.
you will rub with a 255/225 set up on non rolled/pulled fenders.
255's on an 8.5 will give you a bubbly affect on the wheel that will cause you to rub. The offests are little to low, but these are very very do-able though if you dial in the negative camber, rolled/pulled front and rears, with the addition of relocating the rr bumper tab.
I however, would run stock ap2 tire sizes of 245/215
I run run this setup but I have a +48 front and +45 rear, the rears with 2.3deg camber rub only on really hard bumps which is like once every 2-3 weeks. Have yet to have them rub on track. Stock suspension btw
