I need feedback on the following...
I'm looking into a set of wheels with the following sizes available:
front: 18-7.5, 48mm offset(225-40-18)
rear: 18-8.0, 40mm offset OR 18-8.5, 35mm offset(245 or 255-35-18)
Can't decide on the rear size and looking for feedback.
one more thing my MY03 is lowered on Spoon springs with stock pogo sticks.
Thanx in advance
j
Thanx in advance
j
None of those will work. Go here to find out why:
https://www.s2ki.com/forums/index.php?showtopic=342793
My concern is mostly regarding the rear set up, however, your front choice will also rub on heavy suspension compression. You need much higher offset, particularly since you are lowered. With a 245, you'll still be better off with a +60mm offset and with a 255, at least a +65mm offset. Being lowered, this might still be a bit of a problem.
Your biggest concern is offset. Please read that thread I linked and the threads that are linked in that one to understand what you are dealing with.
