I need a camber kit
I need a camber kit
Hey guys, my car is lowered 2in all around and I have some camber....my tires are being worn more in the inside so im wanting to get one. My question is where can I get a good brand fairly cheap? What camber kits do you use?
The car should also handle much better after a proper alignment.
UMM... YOU CAN CHECK OUT COMPTECH... THEIR CAMBER WORKS PRETTY WELL BUT I ONO WHAT IS YOUR BUDGET, THEY RUN ABOUT $100 EACH... IF YOU NEED THEM YOU SHOULD CHECK SP-ENGINEERING
I think this may be what you're talking about (from Comptech), but note that this is NOT a "camber kit." It's an offset ball joint which allows for additional camber adjustment. Totally different animals.
Offset ball joint:
Offset ball joint:
