I lose 4psi per month...is this normal or excessive?
I have 3 month old s2k...oem rims, oem s02's...
I lose about 4psi per month on all 4 wheels...I think this is excessive...is it?
Well, it's Fall, so this is probably normal. If temperatures are decreasing in your area that can contribute to pressure decrease.
All 4 tires are decreasing at about the same rate, and this is consistent with temperature drop.
When measuring tire pressure, make sure that you keep all variables the same. Use the same tire pressure guage each time. I've seen variations of several psi between good quality pressure guages, and those guages at the gas station are notoriously innacurate. Check the pressure when the tires are cold (e.g. first thing in the morning). Tire pressure normally increases as much as 4-5 psi when the car is driven, so make sure that's not the issue.
I may think I have my tires at 32psi...but they're really at say 30psi if I used another good quality guage? That sucks.
yea, I always measure on cold tires.
Clayman
01-12-2004 09:11 AM
