I have the SSR GT1 18 inches, what is the widest tire size for the rear wheels (18x9)
Old 08-14-2003 | 09:55 PM
s2000turbo's Avatar
Default I have the SSR GT1 18 inches, what is the widest tire size for the rear wheels (18x9)
I have 245/35-18 , my car is lower 1 inch with Eibach pro kit, I want to know if I can fit like 265/35/18 or something like that (rear wheel 18x9)
Thanks
Anthony
Old 08-18-2003 | 04:15 PM
Unicron's Avatar
18x9's, and lowered one inch?
Less than +55mm...I would stick with 245/35/18.
255/35/18 with +55mm will rub if you take hard corners or hit a hump in the road.
But it won't cause critical damage to the tire structure. It will just sound bad.
Greater than +55mm and less than +60mm...255/35/18
If you got +65, 265/35/18's.
Old 08-18-2003 | 07:05 PM
s2000turbo's Avatar
Do you know the backspace of the SSR (rear 18x9) of a S2000?
Thanks
Anthony
PD: How I post my car picture?
Old 08-19-2003 | 07:34 AM
Jim@tirerack's Avatar
Former Sponsor
I do agree with Unicorn unless you roll the fender lip. At that point the 255/35R18 will work.
Jim
Old 08-19-2003 | 12:28 PM
PLYRS 3's Avatar
what are you guys talking about?????????
jim, you're the one that recommended 255/35/18's to me when i bought my SSR GT1's a few years ago - 18x9, 55 offset.
they NEVER rubbed.......car was lowered 1.5".
Old 08-19-2003 | 02:14 PM
Unicron's Avatar
[QUOTE]Originally posted by PLYRS 3
[B]what are you guys talking about?????????
Old 08-19-2003 | 02:38 PM
PLYRS 3's Avatar
[QUOTE]Originally posted by Unicron
[B]PLYRS 3,
With 18x9 +55mm offset, I would run 255/35/18's also.
If your car is lowered 1.5 inches...you are on the boarderline of rubbing bud.
It really depends on how you drive and what tire brand you are running.
If you are running S03's or S02's...you will have a higher chance of rubbing than say if you are running 255/35/18 Toyo T1-S.
Old 08-25-2003 | 03:16 PM
Fyrestrike's Avatar
he he......try granpaw.
seriously, i drive my car pretty hard - especially in the twisties and turns (i'm not really a straight line kinda guy).
i was running S-03's with KG/MM race springs.....and say what you will, but i had NO rubbing....maybe every car is a little different???
i am now running the same offsets with the same tires but on 18" SSR Comps - same deal - NO rubbing.
mind you, i have somewhere in the vicinity of -3 degrees camber in the rear.....
Got any pics of the SSR Comps with KG/MM's?
Old 08-26-2003 | 06:08 AM
PLYRS 3's Avatar
here ya' go.................
Old 08-26-2003 | 12:38 PM
Fyrestrike's Avatar
Is it just me or is the back lower then the front?
