I-forged
I-forged
Can anyone give me the best fit for 18 inch three piece I-Forged Aero's on MY04? I'm talkin front and rear width, offset, tire size, suspension change and all. Also, which lowering springs would be best? I'm looking for about an inch drop all around. Any help would be appreciated, thanx.
It completely depends on what you want to run. You could run a 10 inch rim in the rear if you wanted. I have I-forged 17 inch rims and run a 10 inch in the back with a +75 offset. The car is lowered as well. It does rub slightly now due to only one reason, I have almost an inch larger diameter in the rear than stock (although it doesn't rub in autocross, only on really hard bumps in the corners). Reason is because I really wanted a 275+ in the rear and with 17 inch rims, I was screwed. If I had 18 inch rims, I would be fine with no issues looking for the right diameter tires. 18 and +75 for rear with and I forged 10 inch rim will be fine as long as you don't go too far over the overall stock diameter. Stick to that as much as possible.
