Hubcentric rings for volks
Old 07-11-2013 | 11:10 AM
richlbc's Avatar
Default Hubcentric rings for volks
I have a set of Volk LE 28 and not sure what hubcentric rings to buy..Any help much appreciated..Thanks Richard
Old 07-11-2013 | 11:21 AM
Manga_Spawn's Avatar
Site Moderator
Well what is the hub bore on your wheels? Then you just need to find ones that make up the difference in hub bore from the wheel to the actual hub on the S. I forget the exact size but you can find it if you google. Also if you have aftermarket conical lugs (which you should if you have volks) you don't need the rings. The lugs center the wheel correctly assume you torque them right.
MySpaceTOM
09-10-2012 12:36 AM
xPhantom
07-23-2009 09:48 PM
HiPER
10-02-2007 09:47 PM
negcamber
12-27-2006 06:01 PM
kayvan_pour
02-07-2006 11:43 AM
