hubcentric rings for 18x9+29
Offset has nothing to do with it. You need the center bore, which is usually 73.1mm on aftermarket wheels. Then you need different sizes for front and rear hub. You would need 2 rings 73.1mm OD to 70.1 ID, and 2 rings 73.1mm OD to 64.1mm ID.
