How is this set up?
How is this set up?
On the wheels- Work Emotions 17x7 +47 17x8+47
Falken Azenis St115 215/40/17
245/40/17
Is this the optimal set up?
How are the ST115 compared to other tires in situations like auto-x?
Thank you!
245/40/17
Thank you!
don't understand what you're saying...what Jim said is the size you need have unless you want same size all around which in you're case I don't think that's what you're going for...
Well I already have these tires in that size.... should I get new tires? Will it effect my handling that much? I think it will bring a bit of oversteer?
Falken St115
......................Diameter.........Tread width
215/45ZR17......24.6...................7.7
215/40ZR17 .....23.8...................7.4
Stock S02's are 25" diameter so your 215/40's are 1.2 inches shorter, which is significant.
