How long do tires last?
ive never had a rwd car and the tires are 2 different sizes , how do you rotate them ? and how many miles does all the tires get? like a rough estimate
when you rotate the tires do you put the left ones on the right and the rights on the left?
Yes, you can go left to right and vice versa, but NEVER FRONT TO REAR. My rear tires have a habit of hitting the wear markers around 10k. Fronts are usually good for double that, if not more. My Star Specs made it to 8k, but they were almost completely bald at that point. Soft, grippy tires will not last long compared to other tires, but it is worth spending the extra money on those soft, grippy tires.
Rotating side to side isn't worth the effort. IOW, you don't rotate the tires. If you're getting different wear left-side tires vs. right-side tires, your alignment is wack.
Rate of tire wear depends on:
1) The TIRE
2) Alignment
3) type of usage
Rears will typically wear out before the fronts.
If you want maximum life, run "Ultra High Performance" tires instead of "Max Performance" or "Extreme Performance".
For alignment, aim for the minimum amount of toe-in at both ends. Also, you might minimize camber as well, but that doesn't affect tire life as much as toe does, and minimizing camber reduces lateral grip.
1) The TIRE
2) Alignment
3) type of usage
The best life I've gotten out of tires was with Bridgestones - they typically last me ~17k mi and are good tires. On Kumhos and Sumitomos, the only other brands I've tried, I got ~10k on the Kumhos and 13k on the Sumitomos.
Expect to buy a new set of tires at least once a year.
Don't rotate them inless u have non stagered set up. Most people seem to last around 10k miles but thats with fun driving. Im on stock CR tires which are very soft and very sticky im at 11300 miles right now and still have a good 6-7k miles left on the rears. I have not tracked the car yet and most of the roads are flat here. So my tires last some time
You can rotate the rears left to right but if they are directional you will need to dismount the tires from the rim and swap them so you can keep them turnning in the same direction. The free rotation that NTB and Discount Tire provide doesn't cover this type of rotation though. They will charge you about $45 to do this on the front and rear. This type of rotation does get a little more life out of the tires. I've done this on my Mercedes (AMG stags) and S2k for a number of tires and it does work. I swap then at about the 50% wear point. You could probably do it more but I don't like to pay for it more often...
