how do I know if I can fit BBK's?
My front wheel is 18" x 8.5" with a 61 0ffset . 7.5" inner barrel, 1" outer barrel. Can I fit something like a Brembo or Stoptech BBK? If not, what kind of spacer do I need?
No, all rims have different spoke patterns. There is no single offset that will fit or not. The brembo caliper is smaller than the stoptech so you would have to take that into account as well. The only way to know for sure is to find someone with your exact rim and bbk, try it yourself, or use a template like suggested.
Originally Posted by trivium,Oct 3 2006, 02:50 PM
I checked it out but it is pretty confusing to understand.
http://www.stoptech.com/tech_info/ch...29-2430-00.pdf
print it out. measure some of the lines to make sure it printed correctly. Cut along the dotted line and then hold up against the inside of your rim. I think the stoptech templates are pretty user friendly but them I've been looking at them for awhile.
Originally Posted by rijowysock,Oct 3 2006, 11:57 AM
what wheel.. ima just say i HIGHLY doubt it because SSR 8.5 needs +37 offset to fit em,
Work meister need +43
tell me wheel and ill tell u spacer
a bit would need to be around 2" yes inches.
print out the diagram and test fit , i highyl highly doubt the fitment.
wheel makes make different backpads..
normally they sell the low pad so customer gets max lip.
high pads are expensive to make and only sold on a as needed basis.. ud need at least 2" backpad to fit em, im guessing minimum 25mm spacer which would need new studs
